Расшифруте плиз
WAUZZZ8CZPA076112
Идентификация автомобиля - Номер PR
Номер шасси WAUZZZ8CZPA076112 19.03Л1 21:11
Activated carbon canister 1E1 Activated carbon canister
Additional child seat anchors 3B0 Without additional child seat anchor
Additional dust seals 6U0 Without additional seals outside
Additional instrument for distance measurement 8U0 Without additional instruments for distance measurement
Additional instruments 8LA Without additional instruments/switches
Air bag 4UA Without air bag
Antennas 8L0 Without antenna
Anti-theft protection system 9V0 Without anti-theft protection system
Antifreeze 1C1 Antifreeze up to -25 degree celsius tolerance up to -30 degree С
Base engine T4D 4-cylinder gasoline engine 2.0 L unit 048.D
Batteries J1E Battery 220 A (40 Ah)
Body measures 5C0 Without special body measures
Body style K8B Notchback
Bolt-on kit 6GA Without add-on kit
Brake type, front 1LA Disc brakes, front
Brake type, rear 1KB Drum brakes, rear
Braking systems 1AB Power brake
Breakaway interior mirror 4L2 Dipping breakaway interior rear view mirror
Bumper systems 2K0 Standard bumpers
CD changer/CD player 7A0 Without CD changer/CD player
Cassette and CD storage unit 4W0 Without cassette and CD storage unit
Catalytic converter control 8KA W/o catalytic converter warning light
Center armrest 6E0 Without center armrest front
Center armrest rear 6D1 Center armrest rear
Center high-mounted stop light 8R0 Without center high-mounted stop light
Center rear seat belts 3C1 Static lap belt, center rear
Central hydraulic system 2CA Without central hydraulic system
Code plug 9SA Without coding
Component part sets with country- specific design requirements BOA Component parts set
without country-specific design
requirement
Components with special surface appearance 6FA Components without special surface appearance
Control number (no PR-Family) S2S Control (in-plant)
Control number (no PR-Family) S4J "Basic"
Cruise control 8T0 Without cruise control system (CCS)
Cup holder 4M0 Without cup holder
Delivery equipment 2A5 Delivery equipment (transit coating) with thin seat cover
Door and lid locking system 4F1 Central locking system
Door and side trim panels 3LN Unpainted door trim panel
Door pockets, front 3YB Door pockets, front
Drive layout 1X0 Front wheel drive
Electric safety package 9BA W/o additional electric safety package
Engine compartment lighting 9L1 Engine compartment lighting
Engine cooling system 8Z0 Standard engine cooling system
Engine specifications M4U 4-cylinder gasoline engine 2.0 L/66 kW single-point injection, closed- loop cat base engine is T4D
Equipment levels A8S Standard equipment
Exterior noise suppression measures 2B0 Without additional exterior noise suppression
Fire extinguisher 6A0 Without fire extinguisher
First aid kit / warning triangle 1T0 Without first aid kit and warning triangle
Floor mats OTA Without floor mats
Fresh air intake for passenger compartment (with particulate filter) 2V1 Dust and pollen filter
Front fog light/additional headlight 8WA Without front fog light
License plate bracket front (large)
- Идентификация автомобиля Front license plate bracket 6W1
Front seats Q1A Standard front seats
Fuel quantity for initial filling 1Z1 Increase in initial standard fuel filling
Fuel systems 0F2 Fuel system for carburetor gasoline engine
Gearshift boot/cover 6R1 Leatherette gearshift boot
Gearshift knob/handle 6Q1 Plastic gearshift knob/handle
Generators 8GM Alternator 70 A
Generators 9G0 Alternator 130 A
Headlight 8BB Halogen headlight for driving on the right
Headlight activation 8K0 Without special headlight activation
Headlight washer system 8X0 Without headlight washer system
Headlight-range adjustment 8Q0 Without headlight-range adjustment
Headrests 3J1 Height-adjustable headrests for front seats
Heated door lock cylinder 9X0 Without heated door lock cylinder
Heated washer nozzles 9T0 Without heated washer nozzles
Heating and air conditioning system 9AA Manually controlled heating system
Hood and trunk stay 5NB Hood gas prop
Horns 8Y1 Two-tone horn
Identification plates 1EC Special identification plate
Insert for the filling up of unleaded fuel/fuel type 2G1 Insert for the filling up of unleaded fuel
Inserts 5MA Decorative inserts
Installation parts for engine (engine mount system) 1VA Installation parts for four- cylinder engine (two-valve)
Instmment inserts uoc Instrument insert with tachometer clock and km/h speedometer
Interference suppression 8E0 Without interference suppression
Label for central electric 0W1 Label for central electric German- speaking countries
Labels for starting an automatic ОМА Without label for starting an automatic
- Идентификация автомобиля Стр. 4 из 7
Left exterior mirror 3BC Left exterior mirror: adjustable from inside, flat
Left vanity mirror 4SA Without left vanity mirror
Light assistance system 8 GO Without light assistant
Lockable wheel bolts 1PA Standard wheel bolts
Luggage compartment cover 3U0 Without luggage compartment cover
Luggage net/pocket on backrest(s) 4U0 Without luggage nets/pockets on backrests
Malfunction display 9HA Without additional malfunction display
Mud flap 6N0 Without mud flaps
Multi-function display/trip computer 9Q0 Without multi-function display/ on¬board computer
Multi-function display/trip computer 9S0 Without multi-function display/ on¬board computer
Night vision system 9R0 Without night vision system
Outdoor temperature gage 9Y0 Without outdoor temperature gage
Paint preservative/transit coating 5K1 Paint preservative (wax)
Parking light indicator light 8NA Without parking light warning light
Partition 3CA Without partition
Preparation for sound combination for rotating emergency light 9F0 Without sound combination for rotating emergency light and radio antenna preparation
Preparation for special signal systems 9RA W/o special signal system preparation
Preparation for two-way radio installation 9D0 Without preparation for two-way radio installation
Protective side molding 4B1 Protective side molding
Radiator grille 6KA Radiator grille
Radiator installation positions 2R1 Radiator installation position, front
Radios 8AA Without radio
Reading light 8S0 Without reading light
Rear axle ONI Standard rear axle
Rear fog light 8TC Rear fog light for driving on the right
Rear headrests 3Q0 Without rear headrests
Rear heating system/ventilation system 6CA Without rear heating/ventilation duct
Rear seats 3NZ Rear seat bench unsplit, backrest split folding
Rear spoiler 5 JO Without rear spoiler
Rear trim panel 6V1 Rear trim panel (ECE)
Right exterior mirror 3AD Right exterior mirror: convex, adjustable from inside
Right vanity mirror 4TB Vanity mirror right
Roll-up sun screen for rear and side windows 3Y0 Without roll-up sun screen
Roof insert/convertible top 3FA Without roof insert (standard roof)
Roof rails/roof load rack 3S0 Without roof rails/roof load rack
Roof turn signal lights 9H0 Without roof turn signal lights
Safety certificate OLA Without special
plates/stickers/ safety certificates
Safety headrest system 3K0 Without safety headrest system
Seat adjustment 3L1 Manual height adjustment for left front seat
Seat belt check 9P0 Without seat belt reminder
Seat covering N2G Leather seat covering
Seat heater 4A0 Without seat heater
Seat ventilation/massage seat 4D0 Without seat ventilation/massage seat
Second battery/battery installation 8FA Without second battery
Shock absorption/suspension, chassis 1BA Standard suspension/shock absorption
Side and rear windows 4KC Side and rear windows in heat- insulating glass
Side lights 8F0 Without side lights
Ski bag 3X0 Without load-through provision
Sound combination for rotating emergency light 9LA Without rotating emergency lights
Spare wheel/breakdown set 1G2 Steel spare wheel with original equipment tires
Speaker installation 8RA Without speakers
Special alarm systems 9A0 Without taxi alarm system
- Идентификация автомобиля Стр. 6 из 7
Special editions EOA No special edition
Special labels/plates OSE Labels/plates in Dutch
Speedometer cable and seal 8CC Speedometer sensor without seal (electronic speedometer sensor)
Starting aid device 2U0 Without additional starting aid device
Steering 1N1 Power steering
Steering system arrangement LOL Left-hand drive vehicle
Steering wheels IMA Steering wheel
Supertone system and tone sequence control 9J0 Without supertone system and tone sequence control
Tailgate lining 5 HO Without tailgate lining
Telephone/telematics 9 WO W/o car phone preparation/installation
Throttle actuation 0L0 Mechanical throttle actuation
Tires H3C Tires 195/65 R15 T (black)
Top carriers for luggage rack system 3XA Without top carriers for luggage rack system
Trailer hitch 1D0 Without trailer hitch
Trailer hitch 1M1 Trailer hitch preparation
Transmission shafts 1WB Transmission shafts w/100 111111 in diameter
Transmission shafts, rear axle 1YA Without transmission shafts f. rear axle
Transmission specifications GOC 5-speed manual transmission
Transmission types/gearshift mechanisms 0G1 Gearshift lever
Type sign 2Z1 Type sign at rear and "Quattro" nameplates respectively
Vehicle class differentiation units/platform components ODR Installation differentiation for build status of vehicle class В (AUDI) unit components
Vehicle specifications FOA No special purpose vehicle, standard equipment
Wheels C4Z Alloy wheels 6.5J x 17
Window regulator 4R0 Mechanical window regulator
Windshield glass type 4GH Windshield in heat-insulating glass with sunshield
„г , , . ,, . ,,, , ,,nr. Windshield wiper arms/blades
Windshield wiper arms/blades 9PB .. ,.... , .,
' with additional guide vanes
... „„„ Wire assembly for 4-cylinder
Wire assemblies 9EB . . . . . , J . J
fuel miected engine
